> ## Documentation Index
> Fetch the complete documentation index at: https://motorbridge.seeedstudio.com/llms.txt
> Use this file to discover all available pages before exploring further.
# Control loop patterns
# Best Practices: Control Loop Patterns
<mintly-toc>
  This guide covers recommended patterns for reliable motor control loops in production environments.
</mintly-toc>
## Pattern A: Periodic Control + Cached State
Best for high-frequency control loops where fresh state is not critical every iteration.
```python theme={null}
import time
from motorbridge import Controller, Mode
DT_S = 0.02  # 50Hz
with Controller("can0") as ctrl:
    motor = ctrl.add_damiao_motor(0x01, 0x11, "4340P")
    ctrl.enable_all()
    motor.ensure_mode(Mode.MIT, 1000)
    for i in range(1000):
        t0 = time.time()
        # Send control command
        motor.send_mit(pos=0.5, vel=0.0, kp=30.0, kd=1.0, tau=0.0)
        # Read cached state (may be from previous iteration)
        state = motor.get_state()
        if state:
            # Use state for control decisions
            error = 0.5 - state.pos
            print(f"Error: {error:.4f}")
        # Maintain loop timing
        elapsed = time.time() - t0
        if elapsed < DT_S:
            time.sleep(DT_S - elapsed)
**When to use:**
* High-frequency loops (>50Hz)
* State freshness is not critical
* Minimal latency required
## Pattern B: Request-Then-Read
Forces fresh feedback before reading state.
import time
DT_S = 0.02
    ctrl.enable_all()
        t0 = time.time()
        # Request fresh feedback
        motor.request_feedback()
        # Small delay for response
        time.sleep(0.001)
        # Read state (should be fresh)
        if state:
            print(f"Position: {state.pos:.3f}")
        # Send command based on fresh state
        motor.send_mit(0.5, 0.0, 30.0, 1.0, 0.0)
        # Maintain timing
        if elapsed < DT_S:
**When to use:**
* State-based control decisions
* Closed-loop control requiring fresh feedback
* Lower frequency loops (\<50Hz)
## Pattern C: Multi-Motor Batch Query
Efficient pattern for multiple motors.
import time
DT_S = 0.02
MOTORS = ["m1", "m2", "m3", "m4"]
    motors = {
        name: ctrl.add_damiao_motor(i+1, 0x10+i+1, "4340P")
        for i, name in enumerate(MOTORS)
    ctrl.enable_all()
    for motor in motors.values():
        t0 = time.time()
        # Request all feedbacks first
        # Single poll for all (efficient)
        ctrl.poll_feedback_once()
        # Read all states
        states = {name: motor.get_state() for name, motor in motors.items()}
        # Send commands based on states
        for name, motor in motors.items():
            state = states[name]
            if state:
                # State-based control
                target = 0.5 if state.pos < 0.5 else -0.5
            else:
                target = 0.0
            motor.send_mit(target, 0.0, 30.0, 1.0, 0.0)
        # Maintain timing
        if elapsed < DT_S:
**When to use:**
* Multiple motors on same bus
* Coordinated control
* Efficient CAN bus utilization
## Pattern D: State Machine Control
For complex control sequences.
import time
from enum import Enum, auto
class State(Enum):
    INIT = auto()
    HOMING = auto()
    RUNNING = auto()
    ERROR = auto()
DT_S = 0.02
    state = State.INIT
    homing_target = 0.0
    run_target = 1.0
    ctrl.enable_all()
        t0 = time.time()
        # Read state
        motor_state = motor.get_state()
        # State machine
        if state == State.INIT:
            print("Initializing...")
            motor.ensure_mode(Mode.POS_VEL, 1000)
            state = State.HOMING
        elif state == State.HOMING:
            motor.send_pos_vel(homing_target, vlim=1.0)
            if motor_state and abs(motor_state.pos - homing_target) < 0.02:
                print("Homing complete")
                state = State.RUNNING
        elif state == State.RUNNING:
            motor.send_pos_vel(run_target, vlim=1.5)
            if motor_state and abs(motor_state.pos - run_target) < 0.02:
                run_target = -run_target  # Reverse
        elif state == State.ERROR:
            motor.disable()
            print("Error state - stopping")
            break
        # Safety check
        if motor_state and motor_state.t_mos > 80:
            print(f"Overheat: {motor_state.t_mos:.1f}°C")
            state = State.ERROR
        # Maintain timing
        if elapsed < DT_S:
## Pattern E: Graceful Degradation
Continue operation despite errors when safe.
import time
from motorbridge.errors import CallError
DT_S = 0.02
MAX_RETRIES = 3
    ctrl.enable_all()
    consecutive_errors = 0
        t0 = time.time()
        try:
            # Attempt command
            # Read state
            if state:
                print(f"pos={state.pos:.3f}")
        except CallError as e:
            consecutive_errors += 1
            print(f"Error ({consecutive_errors}/{MAX_RETRIES}): {e}")
            if consecutive_errors >= MAX_RETRIES:
                print("Too many errors - stopping")
                break
            # Try to recover
            try:
                motor.clear_error()
                motor.enable()
            except:
                pass
        # Maintain timing
        if elapsed < DT_S:
    motor.disable()
## Bus Load Management
### Avoiding CAN Buffer Overflow (OS Error 105)
If you see `socketcan write failed: No buffer space available (os error 105)`:
**1. Increase control period:**
# Too fast for bus
DT_S = 0.005  # 200Hz - may cause overflow
# Safer
DT_S = 0.02   # 50Hz - usually stable
DT_S = 0.03   # 33Hz - conservative
**2. Increase TX queue length:**
```bash theme={null}
sudo ifconfig can0 txqueuelen 1000
**3. Avoid multiple senders:**
# Bad: Multiple programs sending to same CAN
# Program A and Program B both send commands
# Good: Single sender per CAN interface
**4. Reduce unnecessary feedback requests:**
# Bad: Request every iteration
    motor.request_feedback()  # Every iteration
    motor.send_mit(...)
# Good: Request at lower rate
    if i % 5 == 0:  # Every 5th iteration
    motor.send_mit(...)
### CAN Bandwidth Estimation
| Motors | Rate  | Est. Bandwidth | Risk   |
| 1      | 50Hz  | \~5%           | Low    |
| 4      | 50Hz  | \~20%          | Medium |
| 8      | 50Hz  | \~40%          | Medium |
| 4      | 100Hz | \~40%          | Medium |
| 8      | 100Hz | \~80%          | High   |
## Timing Best Practices
### Measure and Adapt
import time
DT_S = 0.02  # Target 50Hz
for i in range(100):
    t0 = time.time()
    # Your control code here
    sleep_time = DT_S - elapsed
    if sleep_time > 0:
        time.sleep(sleep_time)
    else:
        print(f"WARNING: Overrun by {-sleep_time*1000:.1f}ms")
    # Log actual timing
    actual_dt = time.time() - t0
    if i % 10 == 0:
        print(f"Actual period: {actual_dt*1000:.1f}ms ({1/actual_dt:.1f}Hz)")
### Use High-Resolution Timer
import time
# Prefer time.perf_counter() for timing measurements
t0 = time.perf_counter()
# ... work ...
elapsed = time.perf_counter() - t0
## Safety Patterns
### Watchdog Pattern
import time
LAST_COMMAND_TIME = time.time()
WATCHDOG_TIMEOUT = 0.5  # seconds
def send_command_safe(motor, pos):
    global LAST_COMMAND_TIME
    if time.time() - LAST_COMMAND_TIME > WATCHDOG_TIMEOUT:
        print("Watchdog timeout - sending safe command")
        motor.send_mit(0.0, 0.0, 10.0, 1.0, 0.0)  # Safe position
    motor.send_mit(pos, 0.0, 30.0, 1.0, 0.0)
### Temperature Protection
TEMP_WARNING = 70.0
TEMP_CRITICAL = 85.0
def check_temperature(state):
    if not state:
        return True  # Can't check without state
    if state.t_mos > TEMP_CRITICAL or state.t_rotor > TEMP_CRITICAL:
        return False  # Critical - must stop
    if state.t_mos > TEMP_WARNING:
        print(f"WARNING: High temperature ({state.t_mos:.1f}°C)")
    return True  # OK to continue
## Next Steps
* [Troubleshooting](best-practices/troubleshooting) - Common issues and solutions
* [Tutorial 06: Practical Recipes](tutorials/06-practical-recipes) - Copy-paste code
* [Release and Versioning](best-practices/release-and-versioning) - Version management
