> ## Documentation Index
> Fetch the complete documentation index at: https://motorbridge.seeedstudio.com/llms.txt
> Use this file to discover all available pages before exploring further.
# What is MotorBridge?
<Badge variant="primary">v0.4.1</Badge> <Badge variant="secondary">Rust Core</Badge> <Badge variant="outline">Python Binding</Badge>
MotorBridge is a **unified motor control stack** with pluggable vendor drivers and a C ABI for cross-language integration.
## The Problem We Solve
Every motor vendor has a different protocol:
| Vendor      | Protocol      | CAN Format | Control Modes                  |
| Damiao (达妙) | DM-J4310/4340 | CAN 2.0    | MIT, POS\_VEL, VEL, FORCE\_POS |
| RobStride   | RobStride MIT | CAN 2.0    | MIT, Position, Velocity        |
| MyActuator  | RMD           | CAN 2.0    | Current, Position, Velocity    |
| HighTorque  | HT Native     | CAN 2.0    | MIT, POS\_VEL, VEL, FORCE\_POS |
| Hexfellow   | Hexfellow MIT | CAN-FD     | MIT, POS\_VEL                  |
<Callout type="warn">
  Without MotorBridge, you need to:
  * Learn 5+ different protocols
  * Maintain separate codebases per vendor
  * Rewrite control logic when switching motors
  * Build your own debugging tools
</Callout>
## MotorBridge Architecture
```mermaid theme={null}
flowchart TB
  App["User application"] --> Bindings["Language bindings"]
  Bindings --> Python["Python package"]
  Bindings --> CPP["C++ wrapper"]
  Bindings --> Gateway["WS / ROS2 integrations"]
  Python --> ABI["C ABI: libmotor_abi"]
  CPP --> ABI
  Gateway --> ABI
  ABI --> Core["Rust core: controller, bus, models"]
  Core --> Vendors["Vendor drivers"]
  Vendors --> Damiao["Damiao"]
  Vendors --> RobStride["RobStride"]
  Vendors --> MyActuator["MyActuator"]
  Vendors --> HighTorque["HighTorque"]
  Vendors --> Hexfellow["Hexfellow"]
  Damiao --> Transport["Transport layer"]
  RobStride --> Transport
  MyActuator --> Transport
  HighTorque --> Transport
  Hexfellow --> Transport
  Transport --> SocketCAN["SocketCAN"]
  Transport --> CANFD["SocketCAN-FD"]
  Transport --> DMSerial["DM Serial"]
  Transport --> PCAN["PCAN"]
  classDef top fill:#E0F2FE,stroke:#0284C7,color:#075985;
  classDef abi fill:#F0FDF4,stroke:#16A34A,color:#166534;
  classDef vendor fill:#FEF3C7,stroke:#D97706,color:#92400E;
  classDef io fill:#FCE7F3,stroke:#DB2777,color:#831843;
  class App,Bindings,Python,CPP,Gateway top;
  class ABI,Core abi;
  class Vendors,Damiao,RobStride,MyActuator,HighTorque,Hexfellow vendor;
  class Transport,SocketCAN,CANFD,DMSerial,PCAN io;
<Note>
  The diagram above is the readable system map. The text diagram below is kept as a compact terminal-friendly reference.
</Note>
│                          Your Application                            │
│                     (Python / Future: C++, ROS2)                     │
│    │                    Language Bindings                         │  │
│    │  │   Python     │  │   C++ (WIP)  │  │  ROS2 (WIP)  │      │  │
│    │  │   Binding    │  │   Binding    │  │   Node       │      │  │
│    │                       C ABI (FFI)                            │  │
│    │              libmotor_abi.so / .dylib / .dll                 │  │
│    │  • motor_controller_new_socketcan()                         │  │
│    │  • motor_controller_add_damiao_motor()                      │  │
│    │  • motor_handle_send_mit()                                  │  │
│    │  • motor_handle_get_state()                                 │  │
│    │                     Rust Core                                │  │
│    │  │ motor_core  │ │ motor_abi   │ │ motor_cli   │           │  │
│    │  │ (abstractions)│ (FFI layer) │ │ (CLI tools) │           │  │
│    │  │                   Vendor Drivers                       │ │  │
│    │  │  │ Damiao │ │RobStride│ │MyActuat.│ │HighTorq.│ │Hexfellow││  │
│    │                     Transport Layer                          │  │
│    │  │ SocketCAN  │  │ SocketCAN-FD│  │  DM Serial │            │  │
│    │  │ (CAN 2.0)  │  │  (CAN-FD)  │  │   Bridge   │            │  │
## Project Structure
motorbridge/
├── motor_core/           # Core abstractions (CanBus, MotorDevice)
├── motor_abi/            # C ABI / FFI layer (cdylib + staticlib)
├── motor_vendors/        # Vendor-specific protocol implementations
│   ├── damiao/          # 达妙 motor protocol
│   ├── robstride/       # RobStride motor protocol
│   ├── myactuator/      # MyActuator RMD protocol
│   ├── hightorque/      # HighTorque native protocol
│   └── hexfellow/       # Hexfellow MIT protocol (CAN-FD)
├── bindings/
│   └── python/          # Python binding (ctypes-based)
├── motor_cli/           # Command-line utilities
├── integrations/
│   └── ws_gateway/      # WebSocket gateway for remote control
└── tools/
└── motorbridge-studio/ # Standalone web control UI repo
## Why "Python Binding" Not "SDK"?
<AccordionGroup>
  <Accordion title="What is a Binding?">
    A **binding** is a thin wrapper that exposes a native library to another language via FFI (Foreign Function Interface).
    │  Python Code                                    │
    │  motor.send_mit(pos, vel, kp, kd, tau)          │
                            │ ctypes call
    │  C ABI (libmotor_abi.so)                        │
    │  motor_handle_send_mit(ptr, pos, vel, kp, kd, tau)│
                            │ native call
    │  Rust Core                                      │
    │  DamiaoMotor::send_mit_target(...)             │
    **Key characteristics:**
    * Logic lives in Rust, not Python
    * Python is a 1:1 mapping to C ABI functions
    * No duplicate implementation
    * Minimal overhead (direct FFI calls)
  </Accordion>
  <Accordion title="How the ABI Works">
    The `motor_abi` crate compiles to a shared library:
    ```toml theme={null}
    # motor_abi/Cargo.toml
    [lib]
    crate-type = ["cdylib", "staticlib"]  # Dynamic + Static library
    Python loads it via `ctypes`:
    ```python theme={null}
    # abi.py
    lib = ctypes.CDLL("libmotor_abi.so")
    # Bind function signature
    lib.motor_handle_send_mit.argtypes = [c_void_p, c_float, c_float,
                                           c_float, c_float, c_float]
    lib.motor_handle_send_mit.restype = c_int32
    # Call it
    lib.motor_handle_send_mit(motor_ptr, 0.5, 0.0, 30.0, 1.0, 0.0)
    This is **zero-copy** for primitive types - floats and ints pass directly between Python and Rust.
  </Accordion>
  <Accordion title="SDK vs Binding Comparison">
    | Aspect          | SDK               | Binding (MotorBridge)  |
    | Logic location  | In the SDK itself | In Rust core           |
    | Language        | Pure Python       | Rust + Python wrapper  |
    | Performance     | Python overhead   | Near-native speed      |
    | Memory safety   | Python GC         | Rust ownership         |
    | Other languages | N/A               | Same ABI for C++, etc. |
    | Deployment      | Pure Python       | Need native library    |
    **MotorBridge is a Binding because:**
    * The "SDK" is the Rust core (`motor_core` + vendor drivers)
    * Python is just one interface to that core
    * Future: C++, ROS2 nodes will use the same ABI
  </Accordion>
</AccordionGroup>
## Why Rust for the Core?
| Requirement                | Rust Advantage                          |
| **Real-time control**      | No garbage collection pauses            |
| **Memory safety**          | No buffer overflows, use-after-free     |
| **Deterministic timing**   | Predictable execution for control loops |
| **Zero-cost abstractions** | High-level code, low-level performance  |
| **Cross-platform**         | Linux, macOS, Windows support           |
| **CAN integration**        | Native SocketCAN bindings               |
## Core Components
### Controller
Manages CAN interface and motor lifecycle:
from motorbridge import Controller
# SocketCAN (most common)
with Controller("can0") as ctrl:
    # ctrl manages the CAN socket
    # ctrl tracks all registered motors
    # ctrl handles cleanup on exit
    pass
# CAN-FD (for Hexfellow)
ctrl = Controller.from_socketcanfd("can0")
# DM Serial Bridge (达妙专用)
ctrl = Controller.from_dm_serial("/dev/ttyACM0", 921600)
<Warning>
  It is recommended to bind each Controller to motors from **one vendor**. While the Python API allows mixing different vendors, mixed usage depends on the underlying ABI implementation and may have compatibility limitations.
</Warning>
### Motor
Handle to a single physical motor:
# Add a Damiao motor
motor = ctrl.add_damiao_motor(
    motor_id=0x01,      # Command CAN ID
    feedback_id=0x11,   # Feedback CAN ID
    model="4340P"       # Motor model string
# Control commands
motor.send_mit(pos=0.5, vel=0.0, kp=30.0, kd=1.0, tau=0.0)
# Read state
state = motor.get_state()
### Mode
Control mode determines how the motor responds:
from motorbridge import Mode
motor.ensure_mode(Mode.MIT, timeout_ms=1000)
| Mode        | Parameters            | Use Case                  |
| `MIT`       | pos, vel, kp, kd, tau | Full impedance control    |
| `POS_VEL`   | pos, vlim             | Position with speed limit |
| `VEL`       | vel                   | Pure velocity control     |
| `FORCE_POS` | pos, vlim, ratio      | Force-limited position    |
### MotorState
Real-time feedback structure:
@dataclass
class MotorState:
    can_id: int          # Motor CAN ID
    arbitration_id: int  # CAN arbitration ID
    status_code: int     # Error/status code (0 = OK)
    pos: float           # Position (radians)
    vel: float           # Velocity (rad/s)
    torq: float          # Torque (Nm)
    t_mos: float         # MOSFET temperature (°C)
    t_rotor: float       # Rotor temperature (°C)
## Transport Options
| Transport | Vendors              | Constructor                                         |
| SocketCAN | All except Hexfellow | `Controller("can0")`                                |
| CAN-FD    | Hexfellow (required) | `Controller.from_socketcanfd("can0")`               |
| DM Serial | Damiao only          | `Controller.from_dm_serial("/dev/ttyACM0", 921600)` |
## CLI Tools
The project includes command-line utilities:
```bash theme={null}
# Scan for motors
motorbridge-cli scan --vendor all --channel can0
# Enable and test
motorbridge-cli run --vendor damiao --motor-id 0x01 --mode enable
# Dump registers
motorbridge-cli id-dump --motor-id 0x01 --rids 7,8,9,10
## Integrations
### WebSocket Gateway
Control motors over WebSocket (useful for browser/remote apps):
# Start gateway (installed with pip wheel)
motorbridge-gateway -- --bind 127.0.0.1:9002
From source tree, you can still run:
cargo run -p ws_gateway -- --bind 127.0.0.1:9002
### Motor Calibration
Tool for motor calibration routines:
cd ../motorbridge-studio
npm install
npm run dev
## Comparison with Alternatives
| Feature          | Vendor Libraries | MotorBridge              |
| Multi-vendor     | ❌ One per vendor | ✅ Unified API            |
| Protocol details | ❌ Exposed        | ✅ Abstracted             |
| Type safety      | ⚠️ Varies        | ✅ Full type hints        |
| CLI tools        | ❌ Usually none   | ✅ Built-in               |
| Real-time safe   | ⚠️ Python GC     | ✅ Rust core              |
| Other languages  | ❌ Python only    | ✅ C ABI for any language |
| Documentation    | ⚠️ Varies        | ✅ Comprehensive          |
## Quick Start
<Steps>
  <Step title="Install Python Package">
    pip install motorbridge
  </Step>
  <Step title="Configure CAN Interface">
    sudo ip link set can0 up
  </Step>
  <Step title="Run Your First Program">
    from motorbridge import Controller, Mode
        motor = ctrl.add_damiao_motor(0x01, 0x11, "4340P")
        ctrl.enable_all()
        motor.ensure_mode(Mode.MIT, 1000)
        motor.send_mit(0.5, 0.0, 30.0, 1.0, 0.0)
        print("Motor running!")
  </Step>
</Steps>
## What Can You Build?
<Cards>
  <Card title="Robotic Arms" icon="hand">
    Multi-joint arms with mixed motor vendors
  </Card>
  <Card title="Quadruped Robots" icon="paw">
    12+ motor coordination for walking gaits
  </Card>
  <Card title="Grippers" icon="grip-vertical">
    Force-controlled grasping with FORCE\_POS mode
  </Card>
  <Card title="Test Equipment" icon="flask">
    Automated motor testing and characterization
  </Card>
  <Card title="Wheeled Robots" icon="circle">
    Differential drive with velocity mode
  </Card>
  <Card title="Research Platforms" icon="graduation-cap">
    Rapid prototyping for motor control research
  </Card>
</Cards>
## Next Steps
<CardGroup cols={2}>
  <Card title="Quick Start Guide" href="quickstart" icon="rocket">
    Get your first motor running in 5 minutes
  </Card>
  <Card title="API Reference" href="api/controller" icon="book">
    Complete API documentation
  </Card>
  <Card title="Tutorials" href="tutorials/01-scan-and-identify" icon="graduation-cap">
    Step-by-step practical guides
  </Card>
  <Card title="Best Practices" href="best-practices/control-loop-patterns" icon="shield-check">
    Production-ready patterns
  </Card>
</CardGroup>
