Best Practices: Control Loop Patterns
Pattern A: Periodic Control + Cached State
Best for high-frequency control loops where fresh state is not critical every iteration.
When to use:
  • High-frequency loops (>50Hz)
  • State freshness is not critical
  • Minimal latency required
Pattern B: Request-Then-Read
Forces fresh feedback before reading state.
When to use:
  • State-based control decisions
  • Closed-loop control requiring fresh feedback
  • Lower frequency loops (<50Hz)
Pattern C: Multi-Motor Batch Query
Efficient pattern for multiple motors.
When to use:
  • Multiple motors on same bus
  • Coordinated control
  • Efficient CAN bus utilization
Pattern D: State Machine Control
For complex control sequences.
Pattern E: Graceful Degradation
Continue operation despite errors when safe.
Bus Load Management
Avoiding CAN Buffer Overflow (OS Error 105)
If you see socketcan write failed: No buffer space available (os error 105): 1. Increase control period:
2. Increase TX queue length:
3. Avoid multiple senders:
4. Reduce unnecessary feedback requests:
CAN Bandwidth Estimation
Timing Best Practices
Measure and Adapt
Use High-Resolution Timer
Safety Patterns
Watchdog Pattern
Temperature Protection
Next Steps
